Perspective tags for individual sessions
Hi All
Is it possible to have dedicated tags for each session? I’m building a dashboard where the user can enter some numbers and a script under ‘Project Library’ runs a calculation based on the user input. I tried creating a tag tree under ‘default’ tag provider to store the user inputs but I’m assuming they will be overwritten by each session when multiple users are trying to change the same entry.
Essentially I want to store the user inputs and run calculations which should be agnostic to number of users entering values into the same input variable. Could this be accomplished through custom session props? Open to any approach.
Cheers
Sam
This is what session properties are for.
Thanks, Kevin, I know that was a dumb question :sweat_smile:
Hi Kevin,
Can you explain more on this
This describes the props, but there's also a custom section in the designer for your own props
