Ignition 8.1.
I have created a style with horizontal alignment and applied it to the table. It is not working. Is there something else that is overriding the style I have created? Help please!
Ignition 8.1.
what are you trying to align?
the table exists of many things that can have styles
Hi. I’m trying to get the text in the table to be aligned to the centre of the cell.
The example here should give should show you how: Aligning Text in a Column
In short, I think your style properties are being overwritten by the alignment rules built into the table. You just need to:
props.columns propertyprops.columns.[#].field)props.columns.[#].justify settings to center.
