Perspective Time Series Chart Component Error
I'm trying to plot some queried data in Perspective. My query works on tables just fine:
The script for this:
def updateTable(self):
    queryBase = "SELECT top 1000 t_stamp AS 'Dates'"\
                ",floatvalue AS 'Value'"\
                " FROM sqlt_data_1_2023_08 "\
                "WHERE tagid='286'"
    queryText = queryBase + " ORDER BY t_stamp DESC"
    data=system.db.runPrepQuery(queryText)
    self.props.data = data
I tried to get this data into a timeseries chart with a nearly identical script:
def getData(self):
	                "WHERE tagid='286'"
    self.props.series[0].data = data
The data shows up:
However, the chart just says component error. Is there something else I need to configure? Is there a way that I can trace what's causing the error?
The chart doesn't know your columns names.
By default it expects a time column/key, try renaming Dates to time.
You can probably configure it to use a Dates column, but I'm not sure how - I don't use the time series chart very much.
edit: Yea well I don't know. I've been trying a bunch of things that look like they should work, but no dice.
The timeseries chart component is... weird.
edit2: Even using the same structure as the example chart, I get a component error:
Same names, same timestep, but different values... and it just doesn't work.
The issue here ended up being that the data needs to be in ascending order. That partially fixed things, but I'm still having issues.
