Im looking for a way to have a transparent Embedded SVG Background . The elements should be the only thing I want to show. The 2 Beds need to over lap and I'm using a custom elevation slider to hide them.
Ok i found a Solution . I was Applying a background color to the SVG style itself . Fix Was to remove the background color and apply same color to the root and add 2 zeros at the end for the transparency. Example "#C0C0C000"
