I am looking for an example for the Perspective Tree component use for navigation.
I would prefer to use it instead of the "Menu Tree" component.
I have created teh Tree, but can't work out how to call/display page views
Here's part of one I created.
"label": "Home",
"expanded": true,
"data": {
"url": "/"
"items": []
"label": "Features",
"expanded": true,
"data": {
"url": "/help"
"items": []
"label": "Performance",
"expanded": true,
"data": {
"url": "/myDashboard"
"items": [
"label": "MyMachines",
"expanded": true,
"data": {
"url": "/areaChart/MyMachine 1P"
"items": [
"label": "Mach03",
"expanded": true,
"data": {
"url": "/machine/Mach03"
"items": []
"label": "Mach04",
"expanded": true,
"data": {
"url": "/machine/Mach04"
"items": []
"label": "Mach05",
"expanded": true,
"data": {
"url": "/machine/Mach05"
"items": []
"label": "Mach06",
"expanded": true,
"data": {
"url": "/machine/Mach06"
"items": []
"label": "Mach07",
"expanded": true,
"data": {
"url": "/machine/Mach07"
"items": []
"label": "Mach08",
"expanded": true,
"data": {
"url": "/machine/Mach08"
"items": []
Configure an event on the tree, set it to onItemClicked, select a script action and add the following code.
import urllib
pagePath = self.props.selectionData[0].value.url
system.perspective.navigate(urllib.quote(pagePath))
You'll need to set up each URL on the Page Configuration dialog.
It works really well and makes a nice, clear, easily understood navigation system for an application or site.
Thank you very much for your help.
I now have it working.
Good work.
Don't forget to hit the "Solution" link below the post that best answered your question. That will add the ✓ symbol to your question on the index page.
HI,
Ca you please show in detail.
def runAction(self, event):
import urllib
system.perspective.navigate(urllib.quote(MachineSummaryControls/Line9Summary_trial))
Note: MachineSummaryControls/Line9Summary_trial
this is my view path, that I want to open when clicks on LINE 1
Please guide. Thank you
Your tree's items structure isn't set up correctly. It should be in the form,
items
▼ 0
label : CUPS
expanded : true
▼ data
url : MachineSummaryControls/Line9Summary_trial
Your selectionData looks weird. Where are all the things coming from? If you select CUPS it should look like this:
▼ selectionData
▼ 0
itemPat : 0/0/0
▼ value
The url value is what gets passed into the runAction script.
You have misunderstood. Don't change the selectionData, change items so that selectionData gives the correct result.
system.perspective.navigate(ulrlib.quote('/Line1Page'))
This line will always go to the same page - no matter which option you select on the tree. Instead, use the code I posted in post #2.
Please right-click on the Tree component in Project Browser, Copy and paste the configuration in here so we can replicate your setup. (Format it as code using the </> button. When you post pictures of code we have to type it all out again in our answers.)
sorry, below is the code that copied tree from project browser.
"type": "ia.display.tree",
"version": 0,
"props": {
"items": [
"data": "I am string data for Item 1",
"expanded": true,
"items": [
"data": {
"someKey": "Information here."
"expanded": true,
"items": [
"data": {
"things": [
"one potato",
"two potato",
"three potato",
"four",
"boilem, mash em, put em in a stew"
"expanded": false,
"icon": {
"color": "#869DB1",
"path": "material/arrow_right",
"style": {}
"items": [],
"label": "LINE 1"
"data": 3.14159265359,
"expanded": false,
"items": [],
"label": "LINE 2"
"label": "TARGETACTUAL"
"label": "CUPS"
"data": [
1,
2,
77,
89,
123
"expanded": true,
"items": [
"expanded": true,
"items": [
"expanded": false,
"items": [],
"label": "LINE 1"
"data": {},
"expanded": false,
"items": [],
"label": "LINE 2"
"label": "PRODUCTION STATUS"
"label": "CONES"
"selection": [
"1"
"selectionData": [
"itemPath": "1",
"value": [
1,
2,
77,
89,
123
"appearance": {
"expandIcons": {
"collapsed": {
"expanded": {
"path": "material/arrow_drop_down"
"defaultNodeIcons": {
"expanded": {
"path": "material/folder_open"
"collapsed": {
"path": "material/folder"
"empty": {
"path": "material/stop"
"meta": {
"name": "Tree"
"position": {
"basis": "249px"
"custom": {},
"events": {
"component": {
"onItemClicked": {
"config": {
"script": "\timport urllib\n\tpagePath = self.props.selectionData[0].value.url\n\tpath = 'http://sjohignpgw01s:8088/data/perspective/client/Orion/TargetActual_MES'\n\tsystem.perspective.navigate(urllib.quote(path))\n\t"
"scope": "G",
"type": "script"
below is the script
import urllib
system.perspective.navigate(urllib.quote('/LINE 1 Page'))
please show how to add one more folder under CUPS like TARGETACTUAL.
please find the attached project page.
MENU_Tree.zip (9.3 KB)
In post #6 I asked you,
You didn't answer and the tree structure is still full of amazing garbage! Why are there potatoes and numerical arrays in there and not a single "data" : {"url": "<url>"} structure in there as shown in post #6?
Paste this into the root of the view in your Project Browser. Switch to Preview Mode and watch PROPS.selectionData as you navigate the tree. Then have a look at the data structure to understand how it's supposed to be configured.
"version": 0,
"props": {
"items": [
"data": {
"url": "/overview/cups"
"expanded": true,
"items": [
"data": {
"url": "/overview/cups/targetActual"
"expanded": true,
"items": [
"data": {
"url": "/machine/cups/line1"
"expanded": false,
"items": [],
"label": "Line 1"
"data": {
"url": "/machine/cups/line2"
"expanded": false,
"items": [],
"label": "Line 2"
"label": "Target actual"
"label": "CUPS"
"data": {
"url": "/overview/cones"
"expanded": true,
"items": [
"expanded": true,
"items": [
"expanded": false,
"items": [],
"label": "Line 1",
"data": {
"url": "/machine/cones/line1"
"data": {
"url": "/machine/cones/line2"
"expanded": false,
"items": [],
"label": "Line 2"
"label": "Production status",
"data": {
"url": "/overview/cones/productionStatus"
"label": "CONES"
"selection": [
"1/0/0"
"selectionData": [
"itemPath": "1/0/0",
"value": {
"appearance": {
"expandIcons": {
"collapsed": {
"expanded": {
"expanded": {
"collapsed": {
"empty": {
"meta": {
"name": "Tree"
"position": {
"basis": "506px"
"custom": {},
"events": {
"component": {
"onItemClicked": {
"type": "script",
"scope": "G",
"config": {
"script": "\timport urllib\n\tpagePath = self.props.selectionData[0].value.url\n\tsystem.perspective.navigate(urllib.quote(pagePath))\n\t"
ok will check, get back to you.
when I drag the tree , these potatoes data is coming. I am not getting url
Sorry, I see that now. The tree component is supplied with strange initial data. I never noticed before.
Yes, you need to remove all of those and replace each data with a URL.
very sorry, I am getting same page on all links. below is my settings.
"type": "ia.container.flex",
"version": 0,
"props": {
"style": {
"classes": "Menu/Menu_Vertical"
"meta": {
"name": "root"
"position": {},
"custom": {},
"children": [
"version": 0,
"props": {
"items": [
"data": {
"expanded": true,
"items": [
"data": {
"expanded": true,
"items": [
"data": {
"url": "\"/TargetActual_MES\""
"expanded": false,
"items": [],
"label": "Line 1"
"data": {
"url": "\"/Line9Summary_trial_MES\""
"expanded": false,
"items": [],
"label": "Line 2"
"label": "CUPS"
"data": {
"expanded": true,
"items": [
"expanded": true,
"items": [
"expanded": false,
"items": [],
"label": "Line 1",
"data": {
"data": {
"expanded": false,
"items": [],
"label": "Line 2"
"data": {
"label": "CONES"
"selection": [
"0/0/1"
"selectionData": [
"itemPath": "0/0/1",
"value": {
"appearance": {
"expandIcons": {
"collapsed": {
"expanded": {
"expanded": {
"collapsed": {
"empty": {
"meta": {
"name": "Tree_0"
"position": {
"basis": "506px"
"custom": {},
"events": {
"component": {
"onItemClicked": {
"type": "script",
"scope": "G",
"config": {
"script": "\timport urllib\n\tpagePath = self.props.selectionData[0].value.url\n\tsystem.perspective.navigate(urllib.quote(\"/TargetActual_MES\"))\n\tpagePath = self.props.selectionData[0][1].value.url\n\tsystem.perspective.navigate(urllib.quote(\"/Line9Summary_trial_MES\"))\n\t\t\n"
script:
import urllib
# display Line 1
system.perspective.navigate(urllib.quote("/TargetActual_MES"))
# display Line 2
pagePath = self.props.selectionData[1].value.url
system.perspective.navigate(urllib.quote(**"/Line9Summary_trial_MES"**))
I dont know where I am missing, Is there any video is there for this topic.
The JSON
"url": "\"/TargetActual_MES\"".
You have somehow pasted in strings with escaped quotation marks, \". Remove them. It should read,
"url": "/TargetActual_MES".
"url": "\"/Line9Summary_trial_MES\"".
Same problem. It should read,
"url": "/Line9Summary_trial_MES".
When you look at the properties in the Perspective Property Editor you should not see quotation marks, "..." in any of the values.
The script
import urllib
# display Line 1
# display Line 2
** in the path. Remove those.Ya I got the solution. Thank you so much
i have used code you have given in 2nd post but it is navigating me to the same page every time can you please help
Not if you don't show (1) what you have done, (2) what you expected and (3) what you got.
Look in post #2 at the props.items JSON and, in particular, at the "url" values.
Tip: if you are replying to a specific user then use the Reply button under the post or use the @username syntax so they get an inbox notification.
