Perspective - Unexpected problem unregistering listener from session event bus
Hi all,
I'm getting the below error in my gateway logs referring to an expression binding on a Perspective label component. It seems to populate the error anytime I have the page active. Wondering if anyone has seen this before? The expression binding on props.text is:
{view.params.Label} + ": " + {view.params.Value} + " " + {view.params.Units}
I'm currently running 8.1 RC2 so it's possible it is related to that.
java.lang.IllegalArgumentException: missing event subscriber for an annotated method. Is com.inductiveautomation.perspective.gateway.binding.expression.ExpressionBindingTagListener$SessionEventListener@64bd4089 registered?
at com.google.common.eventbus.SubscriberRegistry.unregister(SubscriberRegistry.java:111)
at com.google.common.eventbus.EventBus.unregister(EventBus.java:201)
at com.inductiveautomation.perspective.gateway.binding.expression.ExpressionBindingTagListener.shutdown(ExpressionBindingTagListener.java:69)
at com.inductiveautomation.ignition.common.expressions.BoundTagExpression.shutdown(BoundTagExpression.java:102)
at com.inductiveautomation.ignition.common.expressions.AbstractExpression.shutdown(AbstractExpression.java:52)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.shutdown(FunctionExpression.java:56)
at com.inductiveautomation.perspective.gateway.binding.PerspectiveExpression.shutdown(PerspectiveExpression.java:174)
at com.inductiveautomation.perspective.gateway.binding.expression.ExpressionBinding.shutdown(ExpressionBinding.java:61)
at com.inductiveautomation.perspective.gateway.model.AbstractBindingHarness.shutdown(AbstractBindingHarness.java:161)
at com.inductiveautomation.perspective.gateway.model.DesignerPageModel$BindingPreviewSupport.modify(DesignerPageModel.java:132)
at com.inductiveautomation.perspective.gateway.model.DesignerPageModel$DesignerHandlers.lambda$new$8(DesignerPageModel.java:310)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:210)
Same issue on my system for any screen object that has logic tied to it such as if this then “Running” else “Stopped” or tag + “:” +tag
It look like this error occurs if the same tag is used in a binding expression more then once such as Tag1/Tag1 or Tag1+Tag2/Tag1
I had this same issue, with a binding that had multiple references to the same tag.
Reorganizing the binding expression to only reference the tag once seemed to have made the problem go away.
We stumbled across the same problem in version 8.1.4 when having multiple references to the same tag on a Perspective component.
Is this the intended behavior or is this a bug? Why do expressions work differently here than they work somewhere else?
Yep, i’m running into the same issue.
Same issue here, with version 8.1.9
We have the same issue with Ignition 8.1.7. Is the IA team working on resolving this or is this an expected behaviour? If it is, is there a reference in the user manual?
Hi, no one news about it?
Thx
This issue is still persisting. Using Version 8.1.14. Is this going to be addressed by someone from @inductiveautomation?
I think I found an issue describing this and the dev work is in progress. I’ll add this thread to the issue.
I just started to see this issue.
I am on 8.1.0 though.
Does it stop your reads? I get the issue in the logs, but the binding seems to be working.
AFAIK this is resolved as of 8.1.17. I don’t think it made your bindings stop working, it was more a bookkeeping issue when shutting them down, I think.
