Perspective - User Source - user not found in user source 'default'
Hi there! I have a Perspective page with authentication enabled, requiring users to log in. After a user logs in the button binding works fine but after sometime, session.props.auth.user.userName is occasionally not found in the default user source . Most of the time, the expression binding works fine, but sometimes this issue happens.
Note that session.props.auth.user.userName always has a value, but the default user source becomes empty when the issue occurs.
Error on button
Expression binding
What do you mean by this? What's your indication of this?
Hi @paul-griffith , it seems like on some rare instances , the users saved on this user source becomes empty and comes back again after a minute or two or reloading the perspective page. (This may be due to network issues, but i thought i share it to you in case there is a similar issue that you've encountered before)
Thanks for the reply
I've never heard of that happening and I don't really see how that could happen with an internal user source; the users and roles in the internal user source are in the same configuration database that holds everything else in your system, and it's stored as a file wherever the gateway is installed.
I would check your gateway logs for errors around the time these issues are happening, and also contact our support department officially.
Thanks for the clarification and suggestion! I'll check the gateway logs for any errors and reach out to the support department if needed. Appreciate your help!
