Ignition 8.1.36 (But I saw it in 8.1.33 so we upgraded to test)
This is a weird one.
I've got a view where the root container is a Flex, and then in that flex container, I've got a breakpoint container.
With nothing in the breakpoint container, I can preview the view all day long and everything is fine. However, if I add a Flex Container to the breakpoint container on the large side, hitting preview and then stopping the preview will cause the breakpoint container to disappear.
Here is the json:
"custom": {},
"params": {},
"props": {},
"root": {
"children": [
"children": [
"meta": {
"name": "FlexContainer"
"position": {
"size": "large"
"props": {
"direction": "column"
"type": "ia.container.flex"
"meta": {
"name": "BreakpointContainer"
"position": {
"basis": "512px"
"props": {
"style": {
"backgroundColor": "#FF8A8A"
"type": "ia.container.breakpt"
"meta": {
"name": "root"
"props": {
I have the background color on there just so I can see if the actual container disappears or if just the components in the container disappear and it seems that the entire container is disappearing.
I can close the view, and re-open it and everything is there. I just can preview it and then stop it and expect things to continue to work.
It doesn't seem to affect the view running in a browser, just in the designer.
Example:
This happens in Windows 10 and Windows 11, as well as newly installed Designers.
There is an error that happens in the console:
15:37:39.616 [Browser Thread: c32e157d-d942-41ac-93d0-2ce9c8ef25c4] ERROR Perspective.Designer.Workspace - level: LEVEL_ERROR
message: "[mobx] Encountered an uncaught exception that was thrown by a reaction or observer component, in: \'Reaction[<component>.render()]\' Error: Minified React error #185; visit https://reactjs.org/docs/error-decoder.html?invariant=185 for the full message or use the non-minified dev environment for full errors and additional helpful warnings."
line_number: 15
source: "http://espdevsrv:8088/res/perspective/js/mobx-5.15.7.js"
Any ideas? I've not tossed this to support yet... hoping someone has seen this before I toss it up.
