Perspective View parameters
I have a problem with passing parameters from page to page.
As in Demo Project I use Cards, which I compose on the Main Page using Embedded Views.
In cards I use view parameters as INPUT and set values in the Main Page.
The question is: sometimes these parameters get values from default values which I set up in cards, but not these which I set on Main page…
What is my problem?
Example:
Card:
new01
Main Page:
new02
The result when I first navigate to the page:
This is the same page when I update some graphic and save the project to client:
and… What 's wrong with Linear Scale? When I first navigate to the page this Element looks bad:
new05
but… after I click on control button (to start/stop pump etc) and then back, so then it looks fine:
new06
Is this a problem because of FLEX Containers? I use them a lot))) or this is problem in me?:neutral_face:
What version of Ignition are you on?
I use 8.0.10 Stable version
Hello PGriffith, I am seeing the same issue in 8.1.0 RC version embedded views where the old parameters are used when page opens and when I perform some other action and come back it displays new parameter values.
Appreciate your help in advance.
It looks like there’s a known regression for 8.1 that should now be fixed - have you tried RC3?
It's currently not available on the downloads page. Is there another place to download RC3?
@code_skin Its actually going through final checks at the moment, but is expected to be up soon.
I don't see it yet under downloads but will try 8.1.0 RC3 once it is made available. Thanks again for your help.
It’s available for me now.
