Perspective view permissions bulk edit (feature request?)?
Is there a way to set up the view permissions for many pages at once? I have to set view permissions for all of them and wanted a faster way than opening each page and setting the permissions.
Maybe it would be a good idea to be able to set permissions on a folder of views which will then apply to every view within the folder?
View permissions are just a key in the view.json file. You could probably use a tool like jq on the command line to automatically go through (recursively?) all views in a folder and make the requisite modification.
Setting up that automation might take longer than just doing it manually, but that’s the automation problem:
That xkcd 2nd graph is missing one thing, the fun factor!
The top graph IS the fun factor. (:
