Can anyone see why I have a vertical scollbar on this coordinate view? There is nothing in the view below the Deviation limit bottom border.
Thanks.
Without having the actual view.json file, no one will be able to tell you. This is likely the result of some sort of styling applied somewhere among the components within the view. If you’re able to supply the relevant view.json file, I could look at this in the next couple of days.
Thanks.
I found that I had rotated the Moving Analog Indicator (in a misguided effort to create a horizontal indicator) and this had upset it. Reverting to zero rotation and changing the aspect ratio for horizontal display fixed it.
