Perspective view with larger resolution
I have pipes in all of my perspective views. I am using coordinate container as piping only available in this type. I have set up mode as percent.
When I run perspective on larger screens, components and pipes are not at the same place.
Also I need to use perspective app, in percent mode it is not working. I have to use fixed mode for app but then I face resolution problem on larger screens.
Please share thoughts.
Have you set the aspect ratio of the coord container? I set this to the resolution of the view, width:heightalso, are all of your other embedded views set to percent mode with aspect ratio set as well?
