Any feedback from this warning please, is it harmless? what might be causing this?
org.eclipse.jetty.websocket.api.CloseException: java.util.concurrent.TimeoutException: Idle timeout expired: 300000/300000 ms
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onReadTimeout(AbstractWebSocketConnection.java:567)
at org.eclipse.jetty.io.AbstractConnection.onFillInterestedFailed(AbstractConnection.java:172)
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillInterestedFailed(AbstractWebSocketConnection.java:540)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.failed(AbstractConnection.java:317)
at org.eclipse.jetty.io.FillInterest.onFail(FillInterest.java:138)
at org.eclipse.jetty.io.AbstractEndPoint.onIdleExpired(AbstractEndPoint.java:407)
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171)
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 300000/300000 ms
... 8 common frames omitted
Thanks!
