Perspective with rendundant servers, browser/mobile client failover
Hi, im having a bit of trouble finding out if this is a feature that is actually supported with automatic failover to the backup node.
With perspective workstation i can find a configuration to set up the failover node, but how is this solved in a browser environment or in the perspective mobile app?
From the documentation it seems like that should be something that is built in to any perspective session.
If the session is already open, it will fail over to the backup node.
If the primary is not available, you will not be able to initially use a browser to the primary, as it is off. You can manually navigate to the backup gateway.
You can also solve this with a proxy server or, as you said, using Workstation
