Perspective Workstation: native file-open dialog (<input type="file">) freezes the entire client
Context:
We have a custom Perspective component (built with the Component SDK) that needs to import a JSON config file from the local filesystem. It uses a standard hidden <input type="file">, triggered via fileInputRef.current.click() from a button handler. This works correctly in Perspective web sessions. In Perspective Workstation, it hangs the entire client.
Steps to reproduce:
  1. In a custom component, have a button call fileInputRef.current.click() on a hidden <input type="file">.
  2. Click that button while running the session in Perspective Workstation.
Observed: the screen darkens as if a file picker is about to open, then nothing happens. The window becomes completely unresponsive and has to be force-closed via Task Manager.
Diagnostics: we attached Chrome DevTools to the session (devTools=true launch argument) before reproducing. No error, warning, or any console output appears at all — the freeze happens before anything returns to JS, and the DevTools connection itself becomes unresponsive along with the rest of the window. This points to the renderer sending a request to the native host asking it to show an OS file-open dialog, and that request never being answered — i.e., Workstation's embedded browser shell doesn't appear to implement the native file-chooser callback that <input type="file"> (and, presumably, showOpenFilePicker()) depends on.
Workaround we're using: drag-and-drop (ondrop/event.dataTransfer.files) instead of the native picker, since that doesn't invoke any native dialog request at all — the OS hands file data to the page directly as part of the drag gesture.
Ask: Is this a known limitation of Workstation's embedded browser shell? Is there a supported way to invoke a native file-open dialog from a custom Perspective component that's known to actually work in Workstation, or is drag-and-drop / the built-in File Upload component the only sanctioned way to get a local file into a Workstation session?
My educated guess is that it's less about what's intended/supported, and much more about what we actually have on hand to test against.
Unfortunately, you're probably a bit stuck until we are able to prioritize fixing this ourselves, which...won't be for a while.
But to your knowledge there is no way to have a Perspective component invoke a native file-open dialogue in Workstation?
What is probably going on, in both this and the other issue you reported, is that we're not implementing some JxBrowser hooks in Workstation. As I said in my first message, that's not out of some intentional restriction on our part; it's simply that we have never needed those capabilities, because none of our first party code uses the same browser hooks/inputs you're trying to use.
What that means for you is fairly little. We provide the module SDK on an "available effort" support basis; there is no SLA or guarantee of fixing bugs that impact module authors like there are actual support contracts for Ignition itself. I'll get a ticket filed internally reporting these issues, then it'll get prioritized into a (large) backlog of other maintenance and feature work, and at some point in the future eventually picked up. I will tell you, at this point in time, the earliest version of workstation that this could end up fixed in would be a future 2027.x release. It's very unlikely to end up fixed in 8.3.x.
Ok, thanks for the info!
