I’m on version 8.1.17
I’m working on an entry form in perspective. The goal is to have the user fill out a form (in a pop-up) and then write that data to a table in a database in SSMS.
Here is the form:
Here is my script so far.
project = 'xxxxx'
query = 'Insert Data'
tx = None
getKey = 1
params = {
'reg_date':self.getChild("EntryForm").getChild("Date TextField").props.text,
'location':self.getChild("EntryForm").getChild("Location Dropdown").props.value,
'lot_num':self.getChild("EntryForm").getChild("Lot Number TextField").props.text,
'variety':self.getChild("EntryForm").getChild("Variety Dropdown").props.value,
'issue':self.getChild("EntryForm").getChild("Issue TextField").props.text,
'detail':self.getChild("EntryForm").getChild("Detail TextField").props.text,
'kg':self.getChild("EntryForm").getChild("Kg TextField").props.text
key = system.db.runNamedQuery(project, query, params, [tx], [getKey])
system.perspective.print(key, destination="gateway")
id = key
view = 'RTFTpopup'
title = str(key) + 'Database record'
position = {'width':800, 'height':800}
system.perspective.openPopup(id, params, title, position, resizeable = True)
I’ve tried to remove the project in line : key = system.db.runNamedQuery(project, query, params, [tx], [getKey])
and it still doesn’t work.
This is the error that I’m getting.
I’ve also tried this script:
# implement your method here
project = 'xxxxx'
tx = None
getKey = 1
params = {
key = system.db.runNamedQuery(query, params)
#key = system.db.runNamedQuery(project, query, params, [tx], [getKey])
id = key
view = 'RTFTpopup'
In this script, I’m getting this error:
Any suggestions?
I’m not sure what the syntax error @P5 means.
