Perspective XY Chart – Allow checking enabled/disabled (greyed) series or axes
It would be very useful if the Perspective XY Chart could provide a way to check which series or Y-axes are currently enabled or disabled (greyed) in the chart legend.
Currently, when users toggle series visibility via the legend:
  • There is no exposed property, binding, or event to determine the enabled/disabled state of each series (In backend - On chart able to see the hide n show charts).
Being able to access this state would allow:
  • Dynamic Y-axis scaling based only on visible series
  • Conditional formatting or data processing for enabled series
  • Simplified logic for multi-axis charts with toggled visibility
For charts with multiple Y-axes, users may toggle series visibility. The Y-axis range, formatting, or data processing should dynamically adjust based on only the enabled/visible series.
You should submit it as a feature request:
Thanks — feature request has been submitted.
For now, I’ve implemented a temporary workaround using checkboxes for each series, bound to the series visible property. Based on the selected series, data is loaded accordingly and the Y-axis min/max values are dynamically adjusted using only the visible series.
Closing this thread for now.
