Perspective XY Chart: Logarithmic value axis cannot have values <= 0
I am working on a perspective project where I am using an XY chart to display some data to the end user. The data is coming from my tag historian set up on some tags that are outputting very small numeric values (we're talking about values down in the 1E-12 to 1E-13 range). I know that leaving the min and max values in the y-axis section of an XY chart lets the chart auto determine what should be the min and max values for displaying your data:
But whenever I check the logarithmic property, I get the following error:
Could someone explain why this is happening and what to do to address this issue? I'm guessing it has to do with my data source and that there are null values or negative values in my datasource.
  1. As a matter of interest, why have you got a binding on yAxes.0.value.logarithmic?
  2. Can you post the chart's dataSource here so we can try it out? See Wiki - how to post code on this forum if required.
  1. I have a binding on yAxes.0.value.logarithmic to allow the end user to toggle between linear scale and logarithmic scale.
  2. My apologies if this is in the incorrect format, here is my datasource:
  "data": [
      "t_stamp": 1729537394789,
      "Series3": 9.999999960041972e-13,
      "Series4": 2.4500000552624135e-12
      "t_stamp": 1729537396589,
      "t_stamp": 1729537398389,
      "Series3": -6.939999790123164e-13,
      "Series4": 1.6600000454086716e-12
      "t_stamp": 1729537400189,
      "t_stamp": 1729537401989,
      "Series3": 2.560000009286384e-13,
      "Series4": 3.6299999464639576e-12
      "t_stamp": 1729537403789,
      "t_stamp": 1729537405589,
      "Series3": 1.8399999406060186e-12,
      "Series4": 3.0699999833960767e-12
      "t_stamp": 1729537407389,
      "t_stamp": 1729537409189,
      "Series3": 4.019999936231977e-13,
      "Series4": 3.3999998996780967e-12
      "t_stamp": 1729537410989,
      "t_stamp": 1729537412789,
      "t_stamp": 1729537414589,
      "Series3": 1.3899999857722167e-12,
      "Series4": 3.520000046650096e-12
      "t_stamp": 1729537416389,
      "t_stamp": 1729537418189,
      "Series3": 6.389999748952768e-13,
      "Series4": 4.440000016953105e-12
      "t_stamp": 1729537419989,
      "t_stamp": 1729537421789,
      "Series3": 1.3300000207064344e-12,
      "Series4": 3.0100000183302944e-12
      "t_stamp": 1729537423589,
      "t_stamp": 1729537425389,
      "t_stamp": 1729537427189,
      "Series3": 5.840000249883459e-13,
      "Series4": 2.5900000460293837e-12
      "t_stamp": 1729537428989,
      "Series3": 6.570000077830984e-13,
      "Series4": 4.729999811964314e-12
      "t_stamp": 1729537430789,
      "t_stamp": 1729537432589,
      "t_stamp": 1729537434389,
      "Series4": 1.860000001241424e-12
      "t_stamp": 1729537436189,
      "t_stamp": 1729537437989,
      "Series3": 1.1100000042382763e-12,
      "t_stamp": 1729537439789,
      "t_stamp": 1729537441589,
      "Series3": -2.0099999681159886e-13,
      "Series4": 2.569999985393978e-12
      "t_stamp": 1729537443389,
      "t_stamp": 1729537445189,
      "Series3": 1.3700000335570284e-12,
      "Series4": 4.0900000400356795e-12
      "t_stamp": 1729537446989,
      "t_stamp": 1729537448789,
      "t_stamp": 1729537450589,
      "Series3": 1.1299999564534646e-12,
      "t_stamp": 1729537452389,
      "t_stamp": 1729537454189,
      "Series3": 1.0400000088547912e-12,
      "Series4": 2.759999910909028e-12
      "t_stamp": 1729537455989,
      "t_stamp": 1729537457789,
      "Series3": 9.670000260600387e-13,
      "Series4": 2.5399998944408697e-12
      "t_stamp": 1729537459589,
      "t_stamp": 1729537461389,
      "Series3": 9.130000087117368e-14,
      "Series4": 3.209999974163047e-12
      "t_stamp": 1729537463189,
      "t_stamp": 1729537464989,
      "Series4": 3.0300000789657e-12
      "t_stamp": 1729537466789,
      "t_stamp": 1729537468589,
      "t_stamp": 1729537470389,
      "Series3": 1.5500000371745926e-12,
      "Series4": 3.6000000723512837e-12
      "t_stamp": 1729537472189,
      "t_stamp": 1729537473989,
      "Series4": 2.189999917523444e-12
      "t_stamp": 1729537475789,
      "t_stamp": 1729537477589,
      "Series3": -9.860000186115436e-13,
      "Series4": 3.1899999135276413e-12
      "t_stamp": 1729537479389,
      "t_stamp": 1729537481189,
      "t_stamp": 1729537482989,
      "Series3": 1.100000014578155e-13,
      "Series4": 2.8499999669279186e-12
      "t_stamp": 1729537484789,
      "t_stamp": 1729537486589,
      "t_stamp": 1729537488389,
      "t_stamp": 1729537490189,
      "Series3": 8.21000006260425e-13,
      "Series4": 3.780000184389065e-12
      "t_stamp": 1729537491989,
      "t_stamp": 1729537493789,
      "Series3": 2.9200001249417296e-13,
      "Series4": 2.2300000387942553e-12
      "t_stamp": 1729537495589,
      "t_stamp": 1729537497389,
      "Series3": 1.639999984773266e-12,
      "Series4": 2.320000094813146e-12
      "t_stamp": 1729537499189,
      "t_stamp": 1729537500989,
      "t_stamp": 1729537502789,
      "Series3": 1.0599999610699795e-12,
      "Series4": 1.4599999811557018e-12
      "t_stamp": 1729537504589,
      "t_stamp": 1729537506389,
      "Series3": 4.559999838664452e-13,
      "Series4": 2.34999996892582e-12
      "t_stamp": 1729537508189,
      "t_stamp": 1729537509989,
      "Series3": -2.560000009286384e-13,
      "Series4": 3.4899999556969874e-12
      "t_stamp": 1729537511789,
      "t_stamp": 1729537513589,
      "t_stamp": 1729537515389,
      "Series3": 7.670000160171775e-13,
      "Series4": 2.870000027563324e-12
      "t_stamp": 1729537517189,
      "Series3": -1.8300000458135873e-13,
      "Series4": 3.1600000394149674e-12
      "t_stamp": 1729537518989,
      "t_stamp": 1729537520789,
      "t_stamp": 1729537522589,
      "Series3": -9.48999993172217e-13,
      "Series4": -3.6499999528892546e-13
      "t_stamp": 1729537524389,
      "t_stamp": 1729537526189,
      "Series3": -2.1900000259436614e-13,
      "Series4": 2.810000062497542e-12
      "t_stamp": 1729537527989,
      "t_stamp": 1729537529789,
      "Series3": 5.480000134228113e-13,
      "t_stamp": 1729537531589,
      "t_stamp": 1729537533389,
      "t_stamp": 1729537535189,
      "Series3": 8.760000103774646e-13,
      "Series4": 2.0599999570741767e-12
      "t_stamp": 1729537536989,
      "Series3": 5.109999879834848e-13,
      "Series4": 5.220000213329579e-12
      "t_stamp": 1729537538789,
      "t_stamp": 1729537540589,
      "t_stamp": 1729537542389,
      "Series3": 9.309999602843955e-13,
      "Series4": 1.8800000618768298e-12
      "t_stamp": 1729537544189,
      "t_stamp": 1729537545989,
      "Series3": 1.67999999762386e-12,
      "t_stamp": 1729537547789,
      "t_stamp": 1729537549589,
      "Series3": 3.099999911718859e-13,
      "t_stamp": 1729537551389,
      "t_stamp": 1729537553189,
      "Series3": 1.4800000417911074e-12,
      "Series4": 2.499999990010493e-12
      "t_stamp": 1729537554989,
      "t_stamp": 1729537556789,
      "t_stamp": 1729537558589,
      "Series3": 1.8300000458135873e-13,
      "Series4": 3.810000058501739e-12
      "t_stamp": 1729537560389,
      "t_stamp": 1729537562189,
      "Series3": 2.7699999412267307e-12,
      "Series4": 2.2099999781588497e-12
      "t_stamp": 1729537563989,
      "t_stamp": 1729537565789,
      "Series3": -4.19999999405965e-13,
      "Series4": 5.589999817201541e-12
      "t_stamp": 1729537567589,
      "t_stamp": 1729537569389,
      "Series3": -9.130000358167911e-13,
      "Series4": 2.660000041412869e-12
      "t_stamp": 1729537571189,
      "t_stamp": 1729537572989,
Isn't the problem that you're asking the chart to get the log of a negative number?
Thought experiment: what value of x in 10x will give you a negative result?
More here:
