Here you go:
"type": "ia.chart.xy",
"version": 0,
"props": {
"xAxes": [
"name": "time",
"label": {
"enabled": true,
"text": "Time",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "category",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "MM/dd HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 60,
"position": 0.5
"font": {
"size": "",
"weight": 500
"yAxes": [
"name": "process temp",
"label": {
"enabled": true,
"text": "Process Temp",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": "",
"weight": 500
"appearance": {
"font": {
"size": "",
"weight": 500
"grid": {
"color": "",
"dashArray": "4,4",
"opacity": 1,
"position": 0.5
"inside": false,
"labels": {
"color": "",
"opacity": 1
"opposite": true
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05,
"startCategory": ""
"date": {
"baseInterval": {
"count": 1,
"enabled": false,
"skipEmptyPeriods": false,
"timeUnit": "hour"
"break": {
"enabled": false,
"endDate": "",
"size": 0.05,
"startDate": ""
"format": "M/d/yyyy",
"range": {
"max": "",
"min": "",
"useStrict": false
"inversed": false,
"label": {
"color": "",
"enabled": true,
"text": "Output Temp"
"name": "output temp",
"render": "value",
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"text": ""
"value": {
"break": {
"enabled": false,
"endValue": 100,
"size": 0.05,
"startValue": 0
"format": "#,###.##",
"range": {
"max": "",
"min": "",
"useStrict": false
"visible": true
"series": [
"label": {
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "example",
"x": "Date_Time",
"y": "621-G54 Y Axis Pull Amount"
"xAxis": "time",
"yAxis": "process temp",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "line",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"width": null,
"height": null,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"candlestick": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"stacked": false,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"open": {
"x": "",
"y": ""
"column": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"height": null,
"stacked": false,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null
"open": {
"x": "",
"y": ""
"data": {
"x": "Date_Time",
"y": "622-G55 X Axis Pull Amount"
"defaultState": {
"visible": true
"label": {
"line": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": false,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "#FF0000",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"render": "line",
"stepLine": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": true,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"visible": true,
"xAxis": "time",
"yAxis": "output temp",
"zIndex": 0
"dataSources": {}
"meta": {
"name": "XYChart_0"
"position": {
"breakpoints": [
"colIndex": 0,
"name": "sm",
"order": 9,
"rowIndex": 1,
"span": 5
"colIndex": 0,
"name": "md",
"order": 9,
"rowIndex": 1,
"span": 5
"colIndex": 0,
"name": "lg",
"order": 9,
"rowIndex": 1,
"span": 5
"height": 343
"custom": {},
"propConfig": {
"props.dataSources.example": {
"binding": {
"type": "property",
"config": {
"path": "../Table.props.data"
"transforms": [
"code": "\tpyD = system.dataset.toPyDataSet(value)\n\tcolNames = list(value.getColumnNames())\n\tkeyNames = [colNames[0]]+colNames[3:]\n\tdateCol = value.getColumnAsList(0)\n\tvalues = [value.getColumnAsList(value.getColumnIndex(keyName)) for keyName in keyNames]\n\n\tdata1 = []\n\trecord = {}\n\tfor i in range(len(pyD)):\n\t\tfor j in range(len(values)):\n\t\t\tif keyNames[j] != 'Date_Time':\n\t\t\t\trecord[keyNames[j]] = round(float(values[j][i]),3)\n\t\t\telse:\n\t\t\t\trecord[keyNames[j]] = values[j][i]\n\t\tdata1.append(record)\n\treturn data1\n\t\n\t'''\n\tdata = []\n\tfor row in pyD:\n\t\tdata.append({\"Date_Time\": row['Date_Time'],\n\t\tcolNames[3]: \"%.2f\" %float(row[3]),\n\t\t\"622-G55 X Axis Pull Amount\": \"%.2f\" %float(row[4])})\n\treturn data\n\t'''\n\t\n#\t[\n#\t {\n#\t \"Date_Time\": \"Tue Dec 10 2021\",\n#\t \"621-G54 Y Axis Pull Amount\": 0.61,\n#\t \"622-G55 X Axis Pull Amount\": 1.48\n#\t },\n#\t {\n#\t \"Date_Time\": \"Tue Dec 11 2021\",\n#\t \"621-G54 Y Axis Pull Amount\": 1.49,\n#\t \"622-G55 X Axis Pull Amount\": 0.54\n#\t },\n#\t {\n#\t \"Date_Time\": \"Tue Dec 12 2021\",\n#\t \"621-G54 Y Axis Pull Amount\": 0.65,\n#\t \"622-G55 X Axis Pull Amount\": 2.07\n#\t }\n#\t]",
"type": "script"
