[Perspective XY Chart] X-Axis date offset by 1 hour
Hi there,
In a perspective XY Chart, the X-Axis is displayed with a 1-hour offset
See below : dataset ranges from 10am to 12pm, whereas X-Axis is displayed from 11am to 1pm
Same issue from within the Designer (same session timezone than the gateway)
Any idea how to fix this ?
Below a summary of my dataset and parameters
dataSource
"ds0": {
"ds",
192,
1695039976849
"$columns": [
"name": "date_lavage",
"type": "Date",
"data": [
1694679000000,
1694679600000,
1694680200000,
1694680800000,
1694681400000,
1694682000000,
1694682600000,
1694683200000,
1694683800000,
1694684400000,
1694685000000
"name": "c01_1_right_up",
"type": "Double",
"data": [
101.979164,
102.10648,
102.5897,
102.170135,
101.77951,
102.59838,
103.0353,
102.49421,
102.30903,
102.54051,
102.546295
"name": "c02_1_left_up",
"type": "Double",
"data": [
103.020836,
102.986115,
102.922455,
102.323494,
102.572334,
103.104744,
103.62558,
103.37384,
103.24364,
103.36806,
103.451965
"name": "c03_1_right_down",
"type": "Double",
"data": [
102.673615,
103.16551,
103.81655,
105.41377,
105.19386,
104.03356,
104.05382,
103.9294,
103.385414,
103.4809,
103.85706
"name": "c04_1_left_down",
"type": "Double",
"data": [
102.49132,
102.728584,
102.91956,
104.46759,
104.86979,
103.86864,
103.729744,
103.6603,
103.295715,
103.521416,
103.56192
"name": "c05_2_right_up",
"type": "Double",
"data": [
101.322334,
101.197914,
101.55382,
101.68403,
102.61864,
101.55382,
101.64931,
101.65799,
101.43519,
101.06481,
101.579865
"name": "c06_2_left_up",
"type": "Double",
"data": [
100.59606,
100.50347,
100.763885,
100.81597,
101.41782,
100.45718,
101.03009,
100.865166,
100.83912,
100.74653,
101.021416
"name": "c07_2_right_down",
"type": "Double",
"data": [
101.99653,
102.02257,
101.74769,
101.69271,
103.53009,
103.85127,
102.24537,
103.142365,
102.734375,
102.103584,
102.572334
"name": "c08_2_left_down",
"type": "Double",
"data": [
104.042244,
104.11169,
104.14352,
104.03935,
105.19676,
105.96354,
104.80035,
105.07523,
104.5978,
104.53125,
104.60648
"name": "c09_3_right_up",
"type": "Double",
"data": [
104.32002,
104.06829,
104.759834,
104.1522,
102.02546,
103.19155,
105.06076,
105.50636,
104.37789,
103.55614,
105.448494
"name": "c10_3_left_up",
"type": "Double",
"data": [
104.34028,
104.03646,
104.80035,
104.10301,
101.77373,
102.546295,
104.05671,
104.48785,
103.41146,
103.11632,
104.99711
"name": "c11_3_right_down",
"type": "Double",
"data": [
110.09549,
110.36748,
110.50636,
110.30093,
109.64989,
110.677086,
111.229744,
111.889465,
111.71875,
110.75231,
111.59433
"name": "c12_3_left_down",
"type": "Double",
"data": [
106.01852,
106.35706,
106.59433,
106.56829,
106.15162,
106.9184,
107.16435,
108.078705,
107.46817,
106.958916,
107.17593
xAxes
"label": {
"enabled": true,
"text": "date de fixage",
"color": ""
"inversed": false,
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "date",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "minute",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "dd/MM/yyyy kk:mm:ss",
"format": "M/dd kk:mm"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 90,
"verticalCenter": "middle",
"horizontalCenter": "middle"
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 10,
"position": 0.5
"font": {
"size": 12,
"weight": 500
yAxes.0
"label": {
"enabled": false,
"text": "",
"color": ""
"inversed": false,
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"value": {
"range": {
"max": 113,
"min": 96,
"useStrict": true
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": "",
"weight": 500
series.0
"label": {
"text": ""
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "ds0",
"x": "date_lavage",
"y": "c01_1_right_up"
"xAxis": "date_lavage",
"yAxis": "c01_1_right_up",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "line",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": false,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "#FFCA8A",
"dashArray": ""
"fill": {
"color": "",
"opacity": 0
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"color": "",
"opacity": 0
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"width": 1,
"opacity": 1
"rotation": 0,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
What is the client timezone? (This looks like normal formatting of date/times on the client side for the chart, while I'm guessing that you formatted the dates in the labels with an expression, which runs in the gateway.)
The data is actually correct, Just the X-axis starts an hour sooner and ends an hour later than you expected, right?
Both ends are "later". (But almost certainly correct for the browser time zone, as shown in the session props.)
This topic might help:
Client tz is Europe/Paris (CET)
Currently the 'Project Timezone' is set to 'Gateway Timezone'
Project Properties > Perspective > General > Project Timezone > 'Gateway Timezone'
No difference when I change it to 'Client Timezone'
For the dates label I just wrote M/dd kk:mm as the output format
Solution : basic date format of the label : M/dd HH:mm instead of M/dd kk:mm ... hence the 1-hour offset, as explained in the documentation.
Thanks @pturmel and @sydney.bosworth for putting me on the path !
https://docs.inductiveautomation.com/display/DOC81/Data+Type+Formatting+Reference
