Perspective xychart
Hello,
I have using XY Chart for show line running status
for the data i have binded the dataset tag. It contains starttime,endtime and some more columns.Then i have added "Add Transform" script for convert dataset to json. Then the endtime of the last row of dataset should be show current time. so, i have put script for same in "Add Transform" script.
now , my problem is:
  • when i added the new row in dataset the chart shows empty. but the output json changed with recent data in props.datasource.example property.
    if the property binding is refresh, it shows chart. I have using self .refreshBinding( "props.datasource.example" ). for refresh binding. but it is shows when the refresh is done by after one second delay .
  • Then the endtime of the last row is changed to current time when the propery binding is works. but i need the last row of end time should be always current time.
Any One Have A Idea Please Provide.
Thanks in advance!.
Please show a sample of your data and your transform code. (Paste as text and use the "Preformatted text" button in the forum editor to style it as code.)
This the Dataset i have binded:
script:
	num_rows = value.getRowCount()
	if num_rows > 0:
		# Get the last row index (0-based)
		last_row_index = num_rows - 1
		# Get the current date and time
		current_datetime = system.date.now()
		# Update the 'endtime' of the last row with the current date and time
		dataset = system.dataset.setValue(value, last_row_index, "end_time", current_datetime)
		row_count = dataset.getRowCount()
		result = []
		for x in range(row_count):
			event_id = dataset.getValueAt(x,0)
			reason = dataset.getValueAt(x,5)
			run_status = dataset.getValueAt(x,7)
			start_milli = system.date.format(dataset.getValueAt(x,1),'yyyy-MM-dd HH:mm:ss')
			end_milli = system.date.format(dataset.getValueAt(x,2),'yyyy-MM-dd HH:mm:ss')
			if run_status == 1:
				color = '#8aff8a'
			elif run_status == 0 and reason == '':
				color = '#808080'
			elif run_status == 0 and reason == 'reason1':
				color = '#0b84a5'
			elif run_status == 0 and reason == 'reson2':
				color = '#ffa056'
			elif run_status == 0 and reason == 'reason3':
				color = '#8dddd0'
			result.append({
				"color":  color,
				"fromDate": start_milli,
				"name" : "",
				"toDate" : end_milli,
				"event_id" : event_id
		return result
You are turning your datetime objects into strings. Don't do that. Just pass them through directly from the dataset. (They will become 64-bit integer milliseconds in the json.)
Hello @pturmel ,
It is working!. But the tooltip shows only date format
i need HH:mm:ss (at least HH:mm)
btw careful for typo
Try setting xAxes.date.break.format.
From here:
https://docs.inductiveautomation.com/display/DOC81/Perspective+-+XY+Chart#PerspectiveXYChart-Properties
this topic has a bunch of examples of formats
@pturmel
it is not working . already the format is with HH:mm
Thankyou!. @victordcq
it is working.
thank you @pturmel for your quick response.
can you both give solution/idea for the my 2 nd point?
you could do the forming of this data in a seperate custom property and then do a structered binding to this custom prop and on a now(5000) (best choose a delay) which only changes the last value.
i wouldnt do it in the same script else you will have to loop through all the data every second(or whatever you delay is)
anyway for just a small delay this seems like a very render expensive thing to do... i wouldnt do it
