Pie Chart label format
Using this post as inspiration, Pie chart labels - #6 by zxcslo,
I have data from a SQL query, two columns, name and seconds (sum). I want to display the seconds as HH:mm:ss. I tried the following code, it doesn’t work, it locks the designer.
from org.jfree.chart.labels import StandardPieSectionLabelGenerator
import datetime
class LabelGenerator(StandardPieSectionLabelGenerator):
	def __init__(self, component):
		self.component = component
		StandardPieSectionLabelGenerator.__init__(self, "")
	def generateSectionLabel(self, dataset, key):
		defaultValues = self.createItemArray(dataset, key)
		return "{0}: {1} ({2})".format(
			key,
			defaultValues[1],
			str(datetime.timedelta(seconds=defaultValues[2]))
	def generatedAttributedSectionLabel(self, dataset, key):
		return null
chart.plot.labelGenerator = LabelGenerator(self)
I also tried returning from SQL as string in HH:mm:ss, but then the value is displaysed as date from 1970 (I just want HH:mm:ss). I tried to format or parse in the above code and that also locked up the designer. What else can I do on this?
‘Locking’ the designer is odd, that probably means the script is going into an infinite loop somehow.
What if you change generateSectionLabel to return a constant string? e.g.
		return "test"
Does that still lock up?
That works fine, also so does this:
				key,
				defaultValues[1],
				defaultValues[2]
Replace defaultValues[2] with str(datetime.timedelta(seconds=defaultValues[2])) and the window will start blinking and then get unresponsive.
It sounds like there might be an uncaught exception happening in your timedelta code then. Try wrapping it in a try: except: block? To see if you can find out the error; it won’t actually fix anything.
Even if I use code from this post:
m,s = divmod(defaultValues[2], 60)
h,m = divmod(m, 60)
time = '{hr:02d}:{mn:02d}:{sc:02d}'.format(hr=h,mn=m,sc=s)
It goes bonkers. The interesting thing is I can't interact with anything on the window, but I can the project browser. I can edit the component in the browser, by disabling the extension. But, even after disabling, the window is still "locked' up. I have to restart the designer. I guess I will give IA a call.
I threw it into the IDE and get this:
Exception in thread "AWT-EventQueue-0" Traceback (most recent call last):
  File "<extension-method configureChart>", line 21, in generateSectionLabel
  File "C:\Users\pgriffith\Projects\ignition\IDE-Launchers\gateway-launcher\src\main\home\user-lib\pylib\datetime.py", line 500, in __new__
    seconds += minutes*60 + hours*3600
TypeError: cannot concatenate 'unicode' and 'int' objects
Try
			key,
			defaultValues[1],
			str(datetime.timedelta(seconds=int(defaultValues[2])))
EDIT: Nope, still not quite there:
ValueError: invalid literal for int() with base 10: '15%'
There it is:
	import datetime
			return "{0}: {1} \n({2})".format(
				key,
				defaultValues[1],
				str(datetime.timedelta(seconds=dataset.getValue(key)))
			return null
Dear Team,
I attempted this. But i wa unable to get the desired outcome.Could you please assist me.
Screenshot 2024-09-30 101054
Show your code.
Otherwise, you've just posted pretty pictures.
EDIT: Also, note that the scripting in this thread is for Vision, and is incompatible with perspective.
