Pie Chart with parameters
Hello,
I’m trying to just make a simple pie chart in the reporting program with three values (up time, static time, and down time). I have all these values being calculated using expression tags. I can import them into the data of the report as a parameter, but I can’t figure out how to inject them into the pie chart.
Thanks for the help
NVM I just ported the tags to my database and then ported them into the Pie chart. Unless someone has a better way of doing it?
That when I would use scripting to add a manually-constructed dataset with the one row.
Could you give me an example or point me to an area that has an example? That would be more efficient than what I have now.
Thanks for the help
There are the “toDataset” scripts: https://support.inductiveautomation.com/usermanuals/ignition/index.html?system_dataset_todataset.htm
You just need to figure out when to run them: on a tag trigger, on a gui timer, … You can save the dataset to a custom memory tag, or directly put it on the table too. The first will run on the server, the second on the client. So if the table is opened seldomly, a gui-timer and writing it directly to the table might be best. If it’s open constantly, on multiple clients, it will be better to calculate the table on tag triggers.
See the section on “Script Data Source” in the user manual’s Scripting in Reporting page.
