Ignition version 8.1.24
Attempting to configure IdP to use client's Ping Federated; we do not have access to Ping Federated setup. The following error is generated when testing login from the Gateway configuration page. Any assistance would be greatly appreciated:
com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterException: Unable to parse the WebAuthResponse from the HTTP request
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapter.parseAttributes(IdpAdapter.java:122)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponseInternal(WebAuthSessionImpl.java:225)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.lambda$onLoginResponse$2(WebAuthSessionImpl.java:250)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.mdc(WebAuthSessionImpl.java:108)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponse(WebAuthSessionImpl.java:250)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterConfigRoutes$TestLoginWebAuthResponseHandler.handle(IdpAdapterConfigRoutes.java:301)
at com.inductiveautomation.ignition.gateway.auth.federation.FederationRoutes.callback(FederationRoutes.java:273)
at com.inductiveautomation.ignition.gateway.auth.federation.FederationRoutes$CrossSiteRouteHandler.handle(FederationRoutes.java:121)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:254)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:61)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Caused by: com.inductiveautomation.ignition.gateway.auth.web.strategy.WebAuthStrategyException: Unable to parse the web auth response from the HTTP request URI: com.inductiveautomation.ignition.gateway.auth.oidc.error.OIDCError@2cadad6f[error=server_error,error_description=,error_uri=,state=eyJraWQiOiJrMSIsImFsZyI6IkhTMjU2In0.eyJqdGkiOiJpSS03VmFPVTZ0eS1Pb2VDRVZ4Zy1aeDRnd1BnUjJPQnI3aTY2YlBVaU0wIiwidXJpIjoiL3dlYi9jb25maWcvc2VjdXJpdHkuaWRwX2FkYXB0ZXJzIn0.Sx-Kip3_sRKP5f_t5O4y0XDRlzmlRZGu3rZrgiYxqlM]
at com.inductiveautomation.ignition.gateway.auth.web.strategy.oidc.OIDCWebAuthStrategy.createExceptionFromOIDCError(OIDCWebAuthStrategy.java:114)
at com.inductiveautomation.ignition.gateway.auth.web.strategy.oidc.OIDCWebAuthStrategy.parseWebAuthResponse(OIDCWebAuthStrategy.java:183)
