Goal: Differentiate various pipe types, without using color.
Ideas:
- In-Line Text,
- Tooltips
- Line Styles (More than the 4 provided)
Question: Has anyone got any of these ideas to work or have any other suggestions?
Ideas:
For some of our customers we use line thicknesses to differentiate between various lines. Since we're oil and gas, we use (in Vision) widths of 5 for main process lines, 3 for liquid process lines (like glycol, amine, etc), and 1 for any slop/dump/discharge lines (all solid). Lines connecting PID blocks/symbols, select blocks, analog input graphics to the process lines are a width of 1 but dashed.
Thank you for the suggestion!
I am trying to differentiate eight (8) various pipe types, so line thickness may not be applicable. But maybe if they can be grouped, I will look into the suggestion. Thanks again.
Being able to vary 2 things to 3 differnt values you can have up to 9 representations. Throw in a column for 3 different text values and you gain an additional 18 variations.
For instance:
Possible Line Style's: Solid, Dashed, Mid Arrow
Possible Line Thickness: 1, 3, 5
Type Number |Line Type | Line Thickness
| Type Number | Line Type | Line Thickness |
| 1 | Solid | 1 |
| 2 | Solid | 3 |
| 3 | Solid | 5 |
| 4 | Dashed | 1 |
| 5 | Dashed | 3 |
| 6 | Dashed | 5 |
| 7 | Mid Arrow | 1 |
| 8 | Mid Arrow | 3 |
| 9 | Mid Arrow | 5 |
I did different sizes for different applications just like this. It really does make it easy to see the different parts of the process
