i have a dataset in which values comes in some order where i am using an equipment schedule component to show that but here i want to show case with alternative of 2 colors if have a machine data
example dataset :
Eq1 val1 - color (darkblue)
Eq2 val2 - color (lightblue)
Eq3 val3 - color (darkblue)
Eq2 val1 - color (lightblue)
Eq1 val2 - color (darkblue)
here instead of adding color based on dataset if it has same machine then alternative color should be given to same machine .
Thankyou
"type": "ia.display.equipmentschedule",
"version": 0,
"props": {
"addEnabled": false,
"resizeEnabled": false,
"moveEnabled": false,
"deleteEnabled": false,
"dateRange": {},
"defaultZoom": "6-hr",
"selectedEvent": {
"itemId": "A-8",
"eventId": null
"progressBar": {
"enabled": false
"currentTimeIndicator": {
"color": "",
"opacity": 0
"rowStyle": {
"borderStyle": "none"
"meta": {
"name": "EquipmentSchedule"
"position": {
"basis": "84%"
"custom": {},
"propConfig": {
"props.dateRange.endDate": {
"binding": {
"config": {
"path": "../flx_search/dt_endDate.props.value"
"type": "property"
"props.dateRange.startDate": {
"binding": {
"config": {
"path": "../flx_search/dt_startDate.props.value"
"type": "property"
"props.items": {
"binding": {
"config": {
"path": "view.params.iItem"
"type": "property"
"props.scheduledEvents": {
"binding": {
"config": {
"expression": "{view.custom.iLoad}"
"type": "expr"
