I’m just starting programming on a rather large process control system (compared to what I’ve been working on before). I therefore feel the need to establish some good standard UDTs for the motors / valves etc.
Does anybody have good examples of the data structures you are using?
I need to build:
- Automatic valve (feedback in both directions).
- Automatic valve (feedback only in open position).
- Automatic valve (no feedback).
- Motor with stepless speed control and PID control (with bus controlled VFD).
What i/o do you have for the Automatic Valve with no feedback?
I like to start with the most basic device and creating a udt for that and then embed that udt in other udt’s that have more signals, or is an assembly of devices.
EX.
UDT:
_Run
_HOA
_Fail
_Pump udt
_VFD Speed
_Manual Speed
_VFD udt
_Valve udt
_Flow Meter udt
As far as specifics… That is why you are the integrator, you have the tools to design a udt that will work best for your application.
Hi Zack,
I have found an open publication for a object structure that I’ve utilized in this project (industrial wastewater filtering / fat flotation and clorine desinfection).
The structure i have used is UNICOS (UNified Industrial COntrol System) developed by the CERN-team.
Although it uses quite large data structures, i have found it to be extremely flexible.
What i find smartest about it is that the structure contains a “parameter” object.
These parameters are for example:
-On/Open feedback present?
-Off/Closed feedback present?
-Local drive allowed?
-Fail safe position open?
Of course these parameters can also be utilized in the SCADA system, which means that i can differentiate the UDT for a valve depending on if the valve has feedback sensors or not.
With only two objects; “Analog” and “ONOFF” i can control all my components; valves (on/off or control), pumps (contactor or VFD driven) etc.
The standard is located here: ab-project-unicos.web.cern.ch/a … bjects.pdf
