Hi everyone.
I’ve got a connection problem.
I need to read data from a PLC5(172.17.xx.xx). To avoid data Exchange through DH, we added an extra network card to the PLC5.
Our connection will be in ethernet through a gateway(10.164.yy.yyy)
I tried a connection using allen Bradley logix driver and putting:
10.164.yy.yyy in the hostname field
and using as connection path: 1,2,2,172.17.xx.xx,1,0
(because in my gateway the network card is in the slot 2).
the device appear in “Connected” status, but in my OPC browser I can see only the “Diagnostic” directory.
What could be the problem?
-----Note that we already sucessfully tried to connect a PLC5 using a network card on a Allen Bradley 5000(our gateway), but with a DH connection (so using the gateway ip as hostname and writing the connection path with the dh node number.). In this case I don’t have a PLC but just a new network card added to the PLC5. ----
No, our PLC5 driver is ethernet only. It has a Connection Path setting you can use.
The correct driver to choose is always the one for the destination device when there’s a path with 1 or more hops. It doesn’t matter how or what you route through. When you pick the Logix driver you’re basically just sending the PLC5 commands it doesn’t understand.
I know everything about my connections,
but I don’t know how to build the connection path using the PLC5 driver.
The user manual says:
“Hostname: type the IP address for the PLC, for example 10.20.4.62
Connection Path: 1,3,2,14 (1 means going to ControlLogix and going to the backplane in PLC 1, 3 is the slot number of the ControlNet module to move to in this example, 2 is the exit port of the ControlNet module, 14 is the address of entry point to the ControlNet module in PLC 2)”
if the hostname is the ip of my gateway,
how I can put the PLC ip into my connection path?
