What is the reason to remove CSV export in 8.0? The legacy CSV import is still there. Without the export, I donāt know the CSV file format. I have to install an old copy to find out???
I have 16,000 tags needed to copy over from WW DBdump which is in CSV/Excel format.
CSV export was removed because configured Ignition 8 tags cannot be exported to CSV; in 7.9 exporting to CSV was already ālossyā because it wouldnāt preserve configured alarms, and with the complete ground-up overhaul of tags in 8.0, they are too dynamic in structure to export to a flat format like CSV.
We went to great pains to make sure that a CSV file that worked in 7.9 would still import into 8.0, but at some point backwards compatibility has insurmountable limitations. CSV import/export was already considered ādeprecatedā from 7.6+, when we introduced the new alarming system to replace the legacy āalertingā.
I knew the mindset at IA was so, but always good to keep hearing it! Future-thinking, that is.
Ignition certainly isnāt the example here, but there are only so many retro-fixes you can make to an application to improve the functionality of an outdated, limiting, and decrepid codebase. One particular other SCADA platform springs to mind that is on its last legs because their product still uses the codebase from 20-25 years ago as its foundary⦠(Not to mention their absurb pricing) At some point in their lifespan, applications need overhauls, not just more bolt-on code!
@anthony_ho, I have older versions of Ignition already installed, let me know what types of tags and what information they use and I will be glad to provide you with an example CSV output. It might be better, however, to write a python (or other favorite language) script that converts the WW file into the JSON format used by IA.
Thanks @mcgheeiv. We have Memory Disc, Int, Real, Msg, and IO Disc, Int, Real, Msg in WW. There must be hundreds of people writing that script already. Have you seen one floating around so I donāt have to reinvent the wheels?
You should really spend some time to create a window that you can import a list of tags with name, opcitempath, datatype, alarming etc that will use the system.tag.configure to create a mass list of tags.
Just curious - has anyone built a window like this that they are willing to share with the community? Iām working on one right now, but if thereās one out there already, would save me re-inventing the wheel.
@Travis.Cox I think this āpower user toolā would be a good resource for Sales Engineering to create. I would advocate making one for Vison and Perspective.
I have one of these windows, but I think like many other integrators giving away a tool that took days to create and debug is not likely. Plus mine does not look polished at all because it is just used internally.
@greg.krueger . It is well worth the time to have your own import window because you may have specific functionality needs for your import. I would also suggest you make an export window as that is important as well if you need to make massive updates to your tags. Also pro tip. Use the JSON names that are given in the user manual for your dictionary values. Otherwise very strange things happen to your tagsā¦
Brandon - thanks for the feedback - and I hear you on it being unlikely - I certainly donāt blame anyone for not sharing, but figured it couldnāt hurt to ask - maybe some college student studying controls had some free time and wrote up something spiffy they were willing to share!
@Travis.Cox - for sure would be great if Ignition provided a tool like this out of the box, I think a lot of users would find it very useful.
