Setting up to display pdf file into pdf viewer
I have followed this to the letter but I continue to get a script error, and I can’t figure out why, I have worked on this till I am blue in the face.
# Check to see if the property that changed was the Selected Value property.
if event.propertyName = = "selectedValue" :
# Run the query to grab the file name and bytes using the new selected ID value.
system.db.runNamedQuery( "Read File" , { "fileID" :event.newValue})
# Grab the file bytes and name from the same row.
bytes = data.getValueAt( 0 , "filebyte" )(This is my error “data” is not defined!! )
name = data.getValueAt( 0 , "fileName" )
# Load the bytes into the PDF Viewer component.
event.source.parent.getComponent( 'PDF Viewer' ).loadPDFBytes(bytes, name)
