On a page I am designing I have three items. One is a numeric entry box, one is a calendar and the other is a report. The query I have in mind uses the t_stamp column and the calendar component. Here is somewhat what I have for the query code:
select machine, accum, t_stamp, shift from prodtrack where shift = {root container.shift} and datediff(day,t_stamp,{root container.calendar.date})=0
I have tried the .text property as well. But it does not like something not sure what. If I use current_timestamp or a put a date in using the single quotes on the property within the { } then the query works.
Example:
and datediff(day,t_stamp,current_timestamp)=0 This works. As does - and DateDiff(day,t_stamp,'10/06/2008'. This also works.
It just seems that when I try to attach to a property under the calendar be it labeled as a text field or a date field then this query does not function. What am I overlooking?
Thanks and have a great day.
