My Setup Ignition-Vision along with Cirrus Link MQTT modules.
I currently have my MQTT broker to only accept MQTT data that is published to "GROUP" - Oil. And all of the Edge of Network devices use Sparkplug b as the protocol.
I now want to use a device that only uses the basic MQTT protocol, is there a why for me to setup a Topic Name Space and have it delivered to a certain group I setup in the Ignition broker?
If you're on Ignition 7.9, then the latest Cirrus Link Modules should be version 3.4.12. They also support Custom Namespaces, though they're not quite as full-featured as in the later 8.x MQTT Engine modules. Take a look at this doc (from their 7.9 compatible MQTT Engine module configuration) and scroll down to Custom Namespace: ME: Configuration - MQTT Modules for Ignition 7.x - Confluence
You can supplement your current configuration (which is targeting Sparkplug B topics) with a Custom Namespace configuration. So you can have both subscribed concurrently.
