I know I’m late to the party here but honestly I think it should be both upper and lower camel case.
If you are talking about a singular property use lower camel: startDate, orderQuantity, postageRequired, shippingMethod, etc.
If you are say passing a complex UDT into a template use upper camel so that at a glance you can tell “this property/parameter is different/has more depth to it”
