PoolableConnectionFactory Error
Hello all, when I am trying to establish a database connection using MSSQL server. I have been able to connect the database to other Ignition gateways that were (supposedly) set up identically. I have updated the JDBC driver to a version that works on other gateways. Has anyone seen this error before? Thank you.
Error Codes:
Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: “PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target”. ClientConnectionId:35eec8dc-e61a-42b3-86c2-bcab4f87c789)
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: “PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target”. ClientConnectionId:5087a21c-4c94-41b2-adbe-e4cfa22aaa8a)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:299)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:252)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:582)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: “PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target”. ClientConnectionId:5087a21c-4c94-41b2-adbe-e4cfa22aaa8a
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3680)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2113)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3204)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2833)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2671)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1640)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:936)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
… 12 more
Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2021)
… 21 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source)
at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at java.base/sun.security.validator.Validator.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel$HostNameOverrideX509TrustManager.checkServerTrusted(IOBuffer.java:1702)
at java.base/sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(Unknown Source)
… 34 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
at java.base/java.security.cert.CertPathBuilder.build(Unknown Source)
… 42 more
8.1.15 (b2022030114)
Azul Systems, Inc. 11.0.14.1
This means your JDBC connection is using SSL/TLS but the server certificate has not been trusted.
If you updated the JDBC driver to 10.1 or later then encryption is now enabled by default. You'll have to either disable it in the connection params or add the server certificate to Ignition's supplemental certificates to be imported.
https://docs.microsoft.com/en-us/sql/connect/jdbc/connecting-with-ssl-encryption?view=sql-server-ver16
https://docs.inductiveautomation.com/display/DOC81/Adding+Security+Certificates+into+KeyStores
Thank you Kevin for your help! I was able to remedy this
Hi, I actually have installed the 11.2 jdbc driver, but I still get the error even though I have installed a self-signed certificate:
this is the error I get:
Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target". ClientConnectionId:69bf76fa-b0a2-4448-95fc-0f5188600923)
Copy
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target". ClientConnectionId:90bfbda6-a3d4-47b5-b50b-cc5d8c555752) at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656) at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534) at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300) at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253) at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096) at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source) Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target". ClientConnectionId:90bfbda6-a3d4-47b5-b50b-cc5d8c555752 at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3806) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1906) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3329) at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2950) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2790) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1663) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1064) at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52) at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357) at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103) at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652) ... 12 more Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1795) ... 21 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) at com.microsoft.sqlserver.jdbc.HostNameOverrideX509TrustManager.checkServerTrusted(SQLServerTrustManager.java:86) at java.base/sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(Unknown Source) ... 34 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 42 more
You're showing me a configuration page for setting up SSL/TLS on the Ignition web server, and that's entirely irrelevant to what's going on here.
The SQL Server instance your connecting to has its own certificate and right now Ignition does not trust it. You need a copy of that certificate to add to Ignition.
Or you need to disable encryption all together by adding encrypt=false to the other parameters in the JDBC connection string.
Never mind: I got it. It was here:
Thank you very much for your help!
It is not working for me. facing the same issue.
Error Message ::
Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "No appropriate protocol (protocol is disabled or cipher suites are inappropriate)".)
