I have a popup (based on a template) that you can access from multiple points in the main window. The values in the pop-up are populated by specific tag values which depend on which button in the main window you press. If you have the pop-up open and then you log in from the main window, the pop -up will change to the default tags of the template, instead of the tags you clicked on.
I’m looking for some help in making sure the values on the pop-up remain the values you initially selected.
Thank you.
