Pop up using scripting
Hello all,
I am trying to put up a pop up on a specific screen on vision app once a step is completed in the PLC ? How do I go about it ?
I do have pop ups but all of them come up when a button is pressed. I need one after a certain step is completed. Any help is appreciated.
Thank You
Pratik Jain
You will need a Client-Scoped tag change script
A similar problem is discussed here: Forum Post
Use an OPC tag to monitor your PLC step sequencer. Then, as @jonathan.taylor suggested, trigger the pop-up to open from a client tag change event script event using a properly configured if statement.
