Populate a Dropdown List with column labels
I have downloaded FactorySQL and FactoryPMI and I am currently evaluating if this is a product for us. Now to my question:
I want the users to be able to select what data to populate a table and a couple of chart objects with. My idea for doing this was to display a dropdown list for every column in the chart where the user could select table columns based on the column names. I am however unable to construct the correct function to achieve this. Can you help me, please?
Database: MySQL
Regards
/T
Ok, let me repeat back to you what it sounds like you're trying to do to make sure I understand you. You want to dynamically fill in the options of a dropdown box with the names of columns from a table of yours, and then use the selectedStringValue property of the dropdown to construct queries that will drive a table and chart.
This sounds great! Filling in a dropdown with column names dynamically is pretty easy using MySQL: you just query the information schema. You'll bind your dropdown's data property to a query that will look something like this:
Just replace mytable and myschema and you should be all set.
Hope this helps,
Carl,
Thank you for your rapid response.
I am duly impressed with the support on a Sunday and everything!
I tried your suggestion and received a number of syntax error messages. After tweaking a bit with the syntax it worked for me. Here is the code that I got working:
SELECT column_name FROM information_schema.columns
WHERE table_schema = ‘myschema’ AND table_name = ‘mygroup’
Can you check if this looks wrong, please. It seems to work, but I am not terribly fluent in SQLish.
Very probably returning here for answers to more questions in the coming week!
Regards
/T
That query looks good to me! And hey - if it works, you know its right!
Let us know when you have more questions,
Carl,
Again, thank you for your support. I will now continue to play with the product.
Regards
/T
