Populating Dataset Expression Tag with runScript calling a global shared script
I created an expression tag on the gateway with data type set to Dataset.
This works correctly:
runScript('system.dataset.toDataSet([],[])')
This doesn’t work:
runScript('shared.tracking.read_data_to_dataset.read_data_to_dataset()')
The script runs fine in the Script Console, the content of the script is:
import system
def read_data_to_dataset():
    return system.dataset.toDataSet([],[])
I also tried using global scope to store the dataset
import system
tracking_data = system.dataset.toDataSet([],[])
    return tracking_data
The error message in Tag Diagnostics is not helpful. Ignition 7.9.2
Problem solved. I didn’t click save.
