Popup Calendar does not save when property change
I have several popup calendars on my reports and I have them all set to NOT DISPLAY the time (But they all do)
I can go change this property save it, close the designer and reopen and it is showing the TIME again.
From the client side it always show the TIME.
It was working but now it is not.
What am I missing?
I found my problem, I’m sorry to have bothered the forum.
It’s not a bother. Please share what happened and what fixed it.
I had the “Format String” property of the popup calendar bound to a string type report parameter. This was causing this property to always revert back. I did not see this when I ask the question. Once I seen it and removed the binding for that property everything worked as it had before.
I somehow had changed it when I was looking over my settings.
