If you create a popup calendar button that displays the date/time and try to edit the date/time (before expanding the calendar with the popup button), the text you enter does not insert but rather overwrites. Once you expand the calendar and you try to edit the time, it then behaves in the normal insert mode.
Yes, this is true, I suppose it’s a bit inconsistent. Perhaps there should be an option for insert vs. overwrite that would apply to both…
