Popup Calendar set Null date
Hi Guys,
I had tried to set a null date to the popup calendar when the dropdown selected value - 1. Can you suggest how to fix this?
Ignition Vision 8.1.17
Thank you,
Priyanka
You could script it from the dropdown's propertyChange event handler:
if event.propertyName == 'selectedIndex' and event.newValue == -1:
	event.source.parent.getComponent('Popup Calendar').date = None
Thank you so much @justinedwards.jle
Worked Perfectly!!
