Is there a way to set a default STARTING date for the popup calendar?
I also don’t want the end user to be able to select anything before the START DATE?
I got this figured out. Thanks
Don’t forget to mark it as solved. I would also recommend putting the answer in the thread. Just in case anyone has the same question, they would be able to find the answer.
OK, Thanks for the tips.
The solution I chose was to re-write my sql query so that only the active records in my table was selected.
