PopUp panel filtering properties on other Perspective view
Hello!
I got a Popup panel with checkboxes I would like to use to filter my main table dataset.
But when I try to reach it properties I cann´t as in propertiews panel I can´t get out of my current view
What would be a way to do this so I can have a filtering panel.
Maybe use an accordiom instead.
Use message handlers.
  • On each checkbox on the popup create an onActionPerformed event. Use system.perspective.sendMessage | Ignition User Manual to send a message to the other view.
  • On the root of the other view create, right-click, Configure Scripts ..., and Add Handler ... You can have this write to custom properties to hold the status of the checkboxes on the popup.
Consider using multiselect dropdowns instead.
Now you don't need a popup and the user can see what has been selected.
