Hey!
I have a onClick Event script for a button that open a Popup with a chart.
And I don’t want the popup to be draggable so I made the script bellow.
But even with this script the popup is draggable.
So if you have any idea on how to help me, I’ll take it !
Thanks !
I checked it on 8.1.15 and draggable = False prevents dragging.
system.perspective.openPopup(id="123", view = 'myColumnView', draggable = False, position = {'left':150, 'top': 50})
True enables dragging too.
Tip: add the ‘Perspective’ tag to your post. It will attract the experts.
Any reason you’re not using the built-in popup ?
The only reason is that when I did that previously, the values in the chart were not the good ones.
But the problem was in my script and I solved it. So now I’ll retry to use the Popup instead.
