Ok, this one has got to be stupid but can anyone tell me why the code below is not working. I have reduced it to a simple test…it is not throwing any error, but it is also not displaying a popupMenu.
app.nav script
[code]def opAdminPopup():
import system, app
def swapArea():
system.nav.swapTo('App Selection')
openwin = system.gui.getOpenedWindowNames()
for win in openwin:
if '/' in win:
system.nav.closeWindow(win)
adminPopup = system.gui.createPopupMenu(["Swap Process Area"],[swapArea])
return adminPopup[/code]
mousePressed and mouseReleased on a button
menu = app.nav.opAdminPopup()
menu.show()
Thanks for the help. I have been staring at the code for hours and I am not seeing it. If it is something really stupid please go easy on me
Hi Wes,
I think you’re forgetting to pass in the event reference. Your script code should be:[code]def opAdminPopup():
import system, app
def swapArea(event):
system.nav.swapTo(‘App Selection’)
for win in openwin:
if ‘/’ in win:
adminPopup = system.gui.createPopupMenu([“Swap Process Area”],[swapArea])
return adminPopup[/code]and the code in mousePressed and mouseReleased should be menu = app.nav.opAdminPopup()
menu.show(event)
I had previously tried the script with the event passing as you showed Al and it didn’t work either. I just added the event pass back in and still nothing. It’s odd, I have added debug print statements and I know I am getting to the return statement in opAdminPopup but no popupMenu.
I tried creating a new window (containing just a label) and script module using your code and it works
The only change I made was to comment out the code inside swapArea and instead put a print statement. This prints correctly every time I right-click the label and choose the ‘Swap Process Area’ option.
Maybe try it in a new window in case something hanging around from before is causing the problem.
This is goofy and it still won’t work. I just recoded a test popup (code below) and still no popup menu. I am getting the “Returning from testpopUp” in output console so I know I am getting in but thats about it.
In case it matters my dev machine is:
Win7 64 Bit
Ignition 7.5.5
Java 7
Here is my app script
[code]def testPopup():
import system, app
def printLabel(event):
print ‘here is my label’
popUp = system.gui.createPopupMenu(['print label'],[printLabel])
print "Returning from testpopUp"
return popUp[/code]
Here is my mouse pressed and mouse released
menu = app.nav.testPopup()
menu.show(event)
I set up a test window with both sets of your code and both worked without issue using the RIGHT mouse click on a button and label component. I could see the message in the console on LEFT click, but no menu on either.
Try adding this to the mousePressed and mouseReleased events
menu.show(event, event.x, event.y)
Thanks,
Adding the event.x, event.y solved the problem for a left click (or touch push). This particular app will primarily be run on touch screens so I wasn’t even thinking about the right mouse click. My original code works fine with a right mouse click incidentally. It make sense (from a windows pop-up perspective) that this popup menu would fire from a right click but I didn’t see anything regarding this in the documentation. Anyways it’s working now and I thank you both (Al and Matlock) for your help. Incidentally nice work on the first post Matlock
Good catch hmatlock! Glad you got it working.
Thanks! Glad you have it working now. I incidentally had the same issue a couple of weeks ago when I was also working on a touch centric app and needed a drop down menu from a button, which you can create using the same approach, just replace the x and y portion.
menu.show(event, 0, event.source.getHeight())
JavaDocs
http://docs.oracle.com/javase/tutorial/uiswing/components/menu.html#popup
