Ports required to launch a designer and a client
With Ignition 8…
What are the required ports for the designer and the vision clients?
I know port 8088 is required. But is there any others that are needed?
Thanks,
Ignition 8 will exclusively use the HTTP/HTTPS port defined in the webserver settings, per the SSL settings of the gateway webserver. Unlike in 7.x, both ports don’t have to be open.
Here is a handy list of what Ignition uses:
https://docs.inductiveautomation.com/display/DOC80/Gateway+Port+Reference
