I was wondering what ports are used by the client that connects to the gateway so that we can firewall our system as tight as possible.
Regards,
Michael
Regards,
Michael
Assuming you’ve used the default ports, it uses 8088 for regular HTTP traffic and 8043 if you’ve enabled SSL/TLS. Note that you need both ports open when you’ve enabled SSL/TLS, not just 8043.
Just to check, because I didn’t mention it, these are the ports that the weblaunched client and weblaunched developer environment use too?
Yep, same ports
