So I’ve been beating myself up trying to get this to work and finally gave up and just rebuilding the table with each change.
- I have a color mapping in a hidden row. If I change the color integer it’s not reflected, even with a repaint call of the parent or table window.
- In the same script I get a memory tag, the path to it is built from data in the table. The first time I read the tag it’s correct, the second time it’s always reading the tag as if built from the data in the first row of the table.
Thanks,
Jake
