I get an internal error when clicking on the devices in the status page - log dump:
Time Logger Message
3:53:24 PM DefaultExceptionMapper Unexpected error occurred
org.apache.wicket.WicketRuntimeException: Exception in rendering component: [Component id = lastConnectError.message]
at org.apache.wicket.Component.internalRenderComponent(Component.java:2562)
at org.apache.wicket.markup.html.WebComponent.onRender(WebComponent.java:56)
at org.apache.wicket.Component.internalRender(Component.java:2365)
at org.apache.wicket.Component.render(Component.java:2293)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1388)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1553)
at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1528)
at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1482)
at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:71)
at org.apache.wicket.Component.internalRenderComponent(Component.java:2535)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1491)
at org.apache.wicket.markup.html.panel.FragmentMarkupSourcingStrategy.onComponentTagBody(FragmentMarkupSourcingStrategy.java:84)
at org.apache.wicket.markup.html.list.ListView.renderItem(ListView.java:585)
at org.apache.wicket.markup.html.list.ListView.renderChild(ListView.java:574)
at org.apache.wicket.markup.repeater.AbstractRepeater.onRender(AbstractRepeater.java:94)
at org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:685)
at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderAssociatedMarkup(AssociatedMarkupSourcingStrategy.java:76)
at org.apache.wicket.markup.html.panel.PanelMarkupSourcingStrategy.onComponentTagBody(PanelMarkupSourcingStrategy.java:112)
at org.apache.wicket.Page.onRender(Page.java:884)
at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:142)
at org.apache.wicket.Page.renderPage(Page.java:1021)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:116)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [Component id = lastConnectError.message, page = com.inductiveautomation.ignition.gateway.web.pages.Status, path = 7:tabPanel:panel:panel:devices:items:11:item-contents:contents-container:contents:lastConnectError.message.Label, isVisible = true, isVersioned = true, markup = [markup = jar:file:/C:/Windows/TEMP/ignition_main_tmp/xopc8356782558055511220.jar!/com/inductiveautomation/xopc/gateway/config/homepage/DevicesPanel.html
Error message, index = 0, current = ‘’ (line 0, column 0)]]
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1620)
at org.apache.wicket.Component.getDefaultModelObjectAsString(Component.java:1643)
at org.apache.wicket.markup.html.basic.Label.onComponentTagBody(Label.java:113)
… 140 more
Caused by: org.apache.wicket.WicketRuntimeException: No get method defined for class: class com.inductiveautomation.xopc.server.devices.DeviceManager$DriverInstance expression: lastConnectError
at org.apache.wicket.core.util.lang.PropertyResolver.getGetAndSetter(PropertyResolver.java:490)
at org.apache.wicket.core.util.lang.PropertyResolver.getObjectAndGetSetter(PropertyResolver.java:341)
at org.apache.wicket.core.util.lang.PropertyResolver.getObjectAndGetSetter(PropertyResolver.java:244)
at org.apache.wicket.core.util.lang.PropertyResolver.getValue(PropertyResolver.java:97)
at org.apache.wicket.model.AbstractPropertyModel.getObject(AbstractPropertyModel.java:86)
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1615)
… 144 more
