Not sure if this is the right topic for it, but there seems to be a memory leak present in beta1 and 2. after a reboot the memory in the VM (clean VM, only ignition installed) crawls to 96% in about 20 minutes. stopping Ignition doesnt not clear up the memory.
There is an AI connection to Antrophic, agents and tools are present:
Let me know if you need logfiles or something
This is dependent on your system and how you have ignition.conf configured. If you've only got a few GB of RAM allocated to your VM and your init and max heap memory in Ignition is configured to use most if not all of it, then it can exhaust your memory. What is your performance page showing in Ignition? It may show it's only using 500MB of RAM, but the JVM will allocate system memory however you have it configured.
Can you confirm, for a start, whether this is the gateway or the designer that you're seeing memory leaks on? What are your memory min/max set to?
That doesn't really make any sense to me. Ignition (whether the gateway or the designer) is a single process. If it's not running, the OS is going to reclaim that memory. If the process is not actually stopping when requested, that's a different story, but if you actively kill the process the OS is definitely going to reclaim that memory.
